My Note 4 won't connect/pair with my bluetooth headset.
Holding down the power button during the pairing process worked for me as well.
At first, I was just turning the bluetooth device on and immediately releasing the button. As others have said, my Note 4 couldn't find the device - not even with several tries and holding the device right next to the phone. After reading this tip though, I tried to pair them again. I held the button down during the process this time, and the phone had no problem finding the device. Yay!
Hi, thank buddy I am able to connect Redmi note 4 to my Bluetooth device with the trick you have mentioned above. Thank you very much once again.
I figured it out - I'm not certain if you have to clear all paired devices first; however, if you hold down the multi-function (on/off) button for about 10 seconds or longer, the voice notification will say, "pairing" and the button LED will flicker; this process then paired with my Samsung Note 4! Good luck.
this is working!!! THANK YOU SO SO MUCH
grossejager you are genius! This method also works with sony SBH24 and Xiaomi Mi A2 Lite - happy that I did not throw away almost new headset :)
That was very helpful my friend, thanks!
Thanks so much 😊 worked for me too!!
witnessloc18
