MyBackup Pro to Dropbox help
ConTejas
866
32
Trying to move my apps/data from my gnex to my N4. I figured this would be a no-brainer. How do you upload the entire "mybackup" folder to dropbox? Says you cannot upload a folder. Uploading each apk and zip cannot be the way to do this lol. Any help or advice? At work so need to use the cloud.
You cannot upload backup from MyBackup Pro to Dropbox, MyBackup Pro offers an online backup storage space which you will need to pay for. I believe carbon backup gives users the option to backup to cloud services like DropBox & Box.
U need to zip the folder. Then after you zip it u can send to db.
Sent from my Galaxy Nexus using Xparent Cyan Tapatalk 2
No, but you sure can upload the data from the backup. ;)
YOU CAN UPLOAD THE FILE TO DROPBOX. YOU NEED TO ZIP THE FILE FIRST THEN TRANSFER TO DROPBOX. OR TRANSFER FILE TO COMPUTER.
Hey guys the new version 4.2 of MyBackup Pro now allows you to use your Dropbox account as the Cloud storage option for Backups and Restore. You can use this by running the app and hitting Menu->Options then select the "Cloud Storage Location" option and selecting Dropbox.
Does Carbon backup screen arrangements and all Apps. Seems like when I tried it and replaced a phone I could not get all apps and no screens?
