Need a better camera app
I wasn't talking about moving people . . . .
My bad. I could have sworn the first sentence in your opening post said:
I like the stock camera app for every situation EXCEPT low light where subjects move.
I just took this handheld shot of a stationary subject while sitting at my computer, 1/6 second exposure, and I don't see a blur problem. Stock app, straight out of camera image with no edits.
I don’t think that snap qualifies as “low light” either.
The OP's complaint was about blur. Blur can result from two things: (1) camera movement while the shutter is open. OP referred to shooting at 1/15. My snap was at 1/6. A steady hand and the camera's image stabilization are clearly sufficient to avoid blur at this slow shutter speed, as I demonstrated; OR (2) subject movement. If a person is moving, there is NO camera in the world that can prevent that subject from being blurred at 1/15 second exposure, which was my point in my first post.
Blur does not result from whether the light is low or high. You can put your camera on a tripod and take a 20 second exposure of a stationary subject in the lowest light and there will be no blur. There might be noise from a high ISO or from the long exposure.
So if you are getting blur at 1/15 second, it is either because of hand movement of the camera while the shutter is open (and you need to stabilize the camera, work on your skills of holding steady, or pick a higher ISO or wider aperture if possible to give you a faster shutter speed) OR it is because your subject is moving (and you either have to ask your subject to hold still or pick a higher ISO or wider aperture if possible to give you a faster shutter speed). Increasing the amount of light by using a flash or other means would be another way to get to a higher shutter speed.
Thinking that there might be some other camera app that will magically take a sharp image of a moving subject at 1/15 is fallacious. Now, if the blur is caused by hand shake (as opposed to subject movement), better image stabilization could potentially help with that, but I doubt that any camera app would be able to improve the camera's image stabilization. That is either a hardware issue or a camera firmware issue.
A lag between the time that you activate the shutter and the time that the shutter opens and closes could potentially cause blur IF you are using a slow shutter speed and have hand movement during the time that the shutter is open. My snap demonstrates that the Note 9 with the stock camera app is fully capable of taking a non-blurred image handheld at 1/6 second. Whether that first shot I posted is low light or not is irrelevant to this point.
Secondarily there could be a different type of "blur" if the shot is out of focus, but I don't think the OP was complaining about that.
But, here you go, another handheld shot, this one at 1/15, and I think it qualifies as a low light shot. I see no blur problem.
Uh, I'm not the OP and I never said that. You've been talking to them and quoting me the entire time.
You're right. My mistake, and my apologies to you for confusing you with the OP.
But I stand by my comments about what does and what does not cause blur in photos.
I'm really interested in finding out if there are ANY camera apps, ports whatever that work well that have a faster shutter speed. Using the Note 9's camera many times results in blur from subjects barely moving. Took quite a few pics at Christmas and the majority have blur, some ridiculously so. Tried using the Pro settings to no avail and for whatever foolish reason, Sammy decided to not include a shutter speed setting. So that results in blurred photos. My S8+ was nothing like this! Very very disappointed in Samsung. You don't spend a thousand dollars on a friggin phone expecting blurred photos!
I can recommend the Google pixel camera port , just search in XDA forums
You can change the shutter speed in Pro mode with the Samsung app. That is how I take most of my pictures.
You might want to try the Pixel camera port as some have suggested. I have that installed also and while I usually use the Samsung camera app, the Pixel app is a little easier to use in low light situations.
Help me out here....I see nothing on my Note 9 that can adjust shutter speed, not in Pro mode not in ANY mode. Where is it? And I may just have to try that Pixel port!
jeffnachatilo
