Need help. Can't turn phone on. Tried TELUS sticky from XDA on fascinate.
epik151
Active member
Feb 25, 2011
40
I didn't know what TELUS was I thought it was code like odin or some other crap but I guess it's a different carrier.
Anyways, I got to step 2 in the guide but then couldn't go any further cause of broken links(like every other guide on that forum).
But now when I press both volume keys and the power button, SGH-T959D comes up, followed by the Galaxy S logo and then phone dies immediately.
How can I hard reset or get back to factory new condition so I can root with a guide somewhere hopefully that exists that lists things step by step.
Thanks.
edit: ok, actually, i was able to get to the "downloading..., do not turn off target!!!" screen.
Thanks.
this wont be so simple to just say i want to reset and start over... lets start with seeing if you can get into download mode
pull your battery and leave it out , plug your phone into the computer and hold the down button for about 10seconds , let me know if it goes into download mode, ...big yellow triangle with an android sweeping and it says do not turn off target
Hey droidxcan, yeah I was able to get there.
But honestly I wouldn't mind resetting and starting over if you can recommend me a good guide.
thats what we are going to attempt now
Do you know how to use odin?
Sorry, my desktop bluescreened.
Yeah I have the general idea. I've only used it this once but I'm sure I could figure it out with some guidance.
Ok, I got to the yellow screen.
It wasn't working with the instructions on that page. I held volume down and plugged in... nothing. I had to insert battery for it to pop up.
Oh, I see. The rar file itself. I had extracted the contents into a folder. My bad.
still on movinand...
Still... do I start panicking now?
on the phone, the downloading bar got about 70% of the way.
never panic, its just a phone
if this doesnt help you may have to follow these directions
Alright, I will try to spell out what we did to fix this. It was a HUGE pain in the butt. This was all trial and error, so YMMV.
First, grab my DI01 All in One. You need an all inclusive package.
http://adrynalyne.us/files/kernels/DI01package3.tar.md5
You will need odin3 v 1.30. Gonna assume you have it, considering the mess you are in.
You also need Heimdall.
Heimdall ? Glass Echidna There is a readme in the windows version zip if you get stuck. Drivers must be installed for it as well.
You also need a copy of the samsung galaxy s usb drivers, because Heimdall will remove them when you use it.
[Drivers] MS Windows x86 and x64 USB Drivers for Samsung Galaxy S - xda-developers
You will also need a PIT file from me:
http://dl.dropbox.com/u/2056318/atlas_v2.2.pit
Steps:
1. Install Heimdall and drivers.
2. Put phone in download mode and plug it in to usb cable.
3. Unzip the Odin file. 7zip can do this, but will give an EOF error. Ignore the error.
4. Choose each section in Heimdall and add the appropriate file, including PIT. Check repartition. Primary boot loader is boot.bin and secondary boot loader is sbl.bin.
5. Start. It should finish and will likely be in a reboot loop with a crap ton of failed errors on wiping data.
6. Reinstall Samsung USB drivers for Odin. This may require a PC reboot.
7. Put phone back in download Mode and start Odin, making sure its detected.
8. Load the entire Odin package, not extracted into the pda section of Odin. Include the PIT file. CHECK repartition.
9. Run the process.
If all goes well, you should be back to stock, crappy Eclair 2.1.
From this thread
http://forum.androidcentral.com/ver...-i-flashed-i9000-phone-odin-i-got-issues.html
kiki2025
