Need help please
If you dont like that phone feel free to send me it. The Optimus S is an all around AWESOME phone.
try to install another recovery. Sounds like a recovery issue if its being aborted. Which ROM are u trying to install?
and then what
If you can get into recovery, go into mounts, mount the sdcard, open up the sdcard on your computer, then transfer the Rom over and unmount it. Then wipe data, cache, dalvik-cache. Then you can flash the Rom! And it will work!
I feel like we are jumping around so much because you still have not explained your situation very well. It's hard to assist anyone if they can't describe their situation...
theres no way to flash a mod just install from zip
STOP! Before you continue, you need to answer this question. When you did the data wipe, did you do it through the recovery menu or through the Settings->Privacy menu?
Also, "install from zip" is what basketthis meant. That's how ROMs are flashed.
it wont even let me put a rom on here this program has screwed me it wont let me change recoverys pretty much wont let me do anything wont let me delete it nothing
yes well i keep trying and it wont let me it tells me amend scripting was deprecated by google in androind 1.5
HuanNguyen
