Need help please
it wont even let me put a rom on here this program has screwed me it wont let me change recoverys pretty much wont let me do anything wont let me delete it nothing
Please answer my question before doing anything else!
STOP! Before you continue, you need to answer this question. When you did the data wipe, did you do it through the recovery menu or through the Settings->Privacy menu?
Congratulations, you bricked your phone by doing the data reset from the Privacy menu.
It's not permabricked though, but it'll take some hard work and patience to get it back up and running. Please read the unbricking guide. DO NOT PERFORM ANY STEPS UNTIL YOU THOROUGHLY READ AND UNDERSTAND EVERY SINGLE PART OF THE GUIDE!
If you even get the notion that this will be too advanced for you, please send me private message. You will get an auto-response, but you can safely ignore that.
no matter what i do i get aborted im bout to smash it
You really did damage. What you did is probably the most harmful thing you could have done to your phone aside from physical damage. But, before you smash it, send it to one of the developers so they can use it.
Just as I suspected. That method is no fun and it will take some time. Make sure you have the drivers first. Uh... You're in deep now. I don't know of a nicer way to put it... Good luck!
I know you've already done it, but this might help shed some light on your situation: http://forums.androidcentral.com/lg...vacy-after-custom-recovery-brick-warning.html
Read through that before attempting anything too. And make sure to follow any directions in DETAIL because one little thing can make a difference. And, just a tip, if it doesn't seem to be working, try a different usb port... Helps sometimes, so figured I'd throw it out there for ya cuz you have a lot ahead of you.
This is why I asked in the beginning if you did a factory reset within recovery. No wonder ur brick isnt working. You need to follow the instructions on the post above or send it to someone to fix it. Idk if sprint will take it back the way it is.... sorry for ur brick
Casperxx99
