need help with signal
Jaredshoes
457
30
My brother in law finnaly switched from webOS to android he bought an incredible he activated it programmed it blah blah his signal bars are showing and everything except for his 3G symbol ive checked everything and his data roaming is on any help?
Reactions: Okaydude#AC
wow i feel dumb i guess ive never noticed that because mine is always on vibrate but still without that symbol now its just showing perfect bars without 3G
yes it actually is greyed out and says turning on but it has said that for about an hour and will sumtimes flicker from being connected to back to turning on....
have you used back up assistant for the phone numbers, you may have to do a factory restore and if that doesnt work i would call verizon or go directly to the store
or call them now and tell them whats going on, maybe they need to reset your plan or something
unreadydrake
