Need help with Thunderbolt Wifi From Mobile network advice!
isaacdibb1095
182
13
Hey.. was wondering if anyone knows any free apps that i can download on my Htc Thunderbolt and just use my mobile network not have to pay for the mobile hot spot... Any suggestions? And i can not hook up with Bluetooth to my Windows 7 Laptop :(
If you have Wifi support on your local network just turn on the TBolt's Wifi and you're on. If not, you can add Wifi to your local network for a one-time access point cost. You don't need any special aps for this.
-Frank
Sent from my HTC ThunderBolt 4G/LTE using Tapatalk
Reactions: isaacdibb1095
-Frank
I was talking if i was trying to hook up to the internet with my laptop with the internet from my thunderbolt... Like make my thunderbolt a mobile router
If you are rooted there are several options. If you are not rooted then the only options you have would require a cable. like clockworkmod tether.
Bantuan
