Needing help with error msg.!
Jondroid2
18
2nd day on Dragon Sky-ICS ROM. Everything is working GREAT! Best one i've been on. I tried downloading a Weather app(Storm Team 12) from google play and got an error message code. I have a buddy that has this app on his Skyrocket (stock ICS) and it looks good. Not sure what info I need to include. Very new at this stuff...sorry. Running the Dragon Sky-ICS build as stated earlier. Please help! Hoping this is a simple fix. Error msg reads....error processing purchase[DF-BPA-09] View attachment 35173
Sent from my SAMSUNG-SGH-I727 using Android Central Forums
Reactions: Jondroid2
I had this problem. I had to do 3 things before it worked for me. Some people it worked after each step but for me I had to do all 3.
1. Go to Settings-> Apps -> All and select Google Play Store. clear cache and then clear data.
2. Go to Settings-> Accounts & Sync and select your current Gmail account. Unsync email, exit out, and sync email.
3. Reboot into Recovery, clear cache and clear Dalvik cache.
Hopefully that helps. Just try one, then test the Play Store. If it doesn't work, try the next step. Good luck
tinni99
