New Firmware Pushed This Morning
Here is the whole screen output:
ClockworkMOd Recovery v3.0.2.5
Use vol keys to highlight and home to select.
reboot system now
apply sdcard:update.zip
wipe data/factory reset
install zip from sdcard
backup and restore
mounts and storage
advanced
+++++Go Back+++++
ClockworkMod Recovery v3.0.2.5
Finding update package...
Opening update package...
Verifying update package...
E:failed to verify whole-file signature
E:signature verification failed
Installation aborted.
Same here also and it powers off if I reboot the system.
I'm stock rooted, and the update is available for me in Flemington, NJ.
So if I were to install the update, would all that would happen be that I just wouldn;t be rooted anymore? I only rooted to remove bloatware, nothing else. Can I install this and just go on my merry way?
Alright I downloaded the update, opted NOT to install it, but not seeing the update anywhere on my phone... Any idea where I can find the file?
I turned off LTE using the app LTE onoff went to 3G and checked again and there it was waiting for me. Downloading now on 3G.
Didn't work for me.
In San Fernando Valley (So. CA) and get SERVICE UNAVAILABLE message on both 3g and 4g.
WTF
Considering what we are hearing about this being pretty much the same update that was leaked, does this patch any holes used to root the phone at all?
Look for update.zip file. It may be on the SD card in no folders, or may be in a folder titled cache either on the SD or on the phone. Use a file explorer program like super manager or root explorer and use the search function to look for "update"
The orginal update was only 22.28 MB in size, while the one I received is 35.649 MB. What was added? See below from VZ support page...
ThunderBolt™ by HTC Software Upgrade
To help you with the mandatory system update for your ThunderBolt by HTC, this page contains the following information:
System Update Instructions
System Update while You Are Roaming
Software update size – 22.28 MB
Estimated software download time – approximately 5 minutes
Estimated software update time – approximately 5 ‐10 minutes
Just downloaded the update over 4g in NYC , took about 2 min to download . No issues what so ever . Installed and checking it out now .
Whenever I go to check updates (did it last week too) my phone just says looking for service, try again. It never says "No updates available" or whatever. Just a service error.
liquidsnake757
