New Firmware Pushed This Morning
Come on guys. Pull the file so the community can use it...
Just connect your phone to the computer and copy the new "update.zip" file out of the cache after it's done downloading but before installing.
I would immediately if I could get it. "Checking for new update available now" box either disappears after a few seconds, or a second one pops up with "service unavailable"..
Reactions: hcrspec
I completely forgot about the saving it for the devs, otherwise I would have. Also, not sure if I would have been able to upload it given the lockdown they have on the computers at work. It's not as bad as some places, but since it's a regulatory environment, there are a lot of locks on uploads and downloads.
Yep.. and when I reboot, it gets into Sense, and then shuts down right away.
Mine did the samething too. I did push the menu button and it brought up the ClockworkMod v3.0.2.5 menu. There it lists a bunch of stuff in adition to "Verifying update package... E:failed to verify whole-file signature. E:signature verification failed. Installation aborted.
Yep.. Now I guess I have to wait for someone to put up the file so I can copy it to SDCard, and hope the manual update from Recovery works..
Anyone know how I can get rid of the Clockwork Mod recovery in my situation? Is that the problem??
I can grab it, but don't want to install it (lose root).
Once it's downloaded, do i still have an option to NOT install it?
Here is the whole screen output:
ClockworkMOd Recovery v3.0.2.5
Use vol keys to highlight and home to select.
reboot system now
apply sdcard:update.zip
wipe data/factory reset
install zip from sdcard
backup and restore
mounts and storage
advanced
+++++Go Back+++++
ClockworkMod Recovery v3.0.2.5
Finding update package...
Opening update package...
So far, camcorder vid sound is the the same, can barely hear recorded voices 7 ft away. I am on the border of 3g/4g and before I was bouncing 4g/3g/1x. Now I have solid 4g.(nassau/suffolk border). Took 2 mins for GPS lock.
Update: It's starting to bounce between 3g/4g but not as often before the update and now it's showing me as being in the next town over.
In San Diego here. Went to "Check New" with LTE on and I got the same error as everyone else.
Error
SERVICE UNAVAILABLE
Check for Software Update under
Settings when service is available
I turned off LTE using the app LTE onoff went to 3G and checked again and there it was waiting for me. Downloading now on 3G.
reboot system now
backup and restore
mounts and storage
advanced
+++++Go Back+++++
Yep, same exact from here...
wish i can help!!! i just rooted phone last night and downloaded the dasbamf 1.6.3 rom and kernel 2.0 from Adrynalyne. now i cant get the update...its say "NO NEW SOFTWARE UPDATE AVAILABLE"...... any body recommend settings on or any app to help battery from being drained so fast??? was 100% this mroning in now about 2 hrs later is at 77%....
New radio, Or try a different rom. I recommend Prefect storm, or Vanilla bean.
Should everyone be rushing to install this? Why should we assume this is an upgrade that we want?
Aruz530
