New OTA to version MF9 is out!
I've noticed an immediate negative impact to battery. Also, it looks like toolbar/taskbar is showing up in lockscreen where it didn't before. I've pulled batteries, done network refreshes, and everything. Any ideas how to fix either issue? Thanks!
I never had the battery problem, but i read on xda that removing your Google account then re adding fixes it
How do you remove tour Google account?
My battery life sucks after update!
I'm pretty sure the only way to do so us to do a factory reset. Its a limitation of android, as it won't let you remove it without a backup account, yet it won't let you add one.
Sent from my paranoid s3...
Go to Settings->Accounts->Tap Google->Tap Your Account(joeschmoo@google.com)->Tap Remove Account in the lower right corner. Then go back to Accounts and re-add it. Hope that helps!
This.
Sent from my T-Mobile HTC One using AC Forums.
I too have had much worse battery life after the update where my wife's s4 is fine. I did a factory reset which seemed to help some, but it's still not back to where it was before the update. Anyone had any luck fixing this or sprint giving them an answer? Should I get it replaced or am I imagining this issue? Thanks.
tryhomematch
