New Speed Charge/Battery Status Lock Screen with annoying ads "just appeared" on GN4
I had same issue - drove me nuts for a week!
I uninstalled apps 1 by 1 and finally!!!
It was Share it app
Now it's gone! Good luck - may be a different app on your phone
Heads Up! I have a Motorola. Don't know how I got the lock screen as well but I do have ES explorer.
Bad thing is I got rid of everything went into my Internal Memory and it Still shows "chargelocker" so that tells me that even if you get rid of the program, part is still in your internal and you must delete it separately. Go into Android then Data - mine said "gochargelocker"
This happened to my new Moto G phone yesterday. I also have a weird add pop up while I'm on my actual home screen that I can only half read. So it's not just a Samsung problem.
Some days ago I removed Z Camera that was giving me this nasty thing:
On every app in Google Play its possible to make a report to Google, I did, and Z Camera is now removed from Google Play!! :D
Zero Team still got some apps there: https://play.google.com/store/apps/developer?id=Zero Team
PLEASE!
If you are finding some program that is malware or don't behave as it should
-> REPORT TO GOOGLE!
So we can get rid of all crappy apps!
Hello, I was wondering I know you removed the charging boost fake charging like in your picture above but do you know to get it instead of remove it the picture you posted above?
I read through all of these but I have none of those apps and I have the screen. I have no idea how to get rid of it
I am having a similar screen to some of the ones I have seen on here but it is slightly different. I have deleted most of the apps on my phone trying to get rid of this and it is driving me crazy! I ran stopbadapp as well as some other adware apps and nothing can find it. Does this look familiar to anyone??
Hi I have a question for you recently I have a screen lock charging notification like you have on your screenshot, where did you activate it?, do your phone rooted? Please tell me how cause I want to bring up that screen lock again,
Patric2204
