Nexus 4 battery life get drained by screen, and random reboots? Need help!!
Erwin Rooij
3
Dear users,
Since few weeks my battery life get drained by my screen. My screen brightness is on his lowest and still draining like 20-30% battery life each hour. Sometimes my screen even drain in stand-by mode... Every other draining apps/things are off. Like sync mail and more are all off.. So its really a problem with the screen... How could I fix this?
And then we have random reboots... My nexus 4 just reboot without any reason. Sometimes its reboot in stand-by mode and sometimes when I use my phone. But both without any reason to reboot... Someone know a fix?
The screen shouldn't consume power when it's off, but when it's on it will be the biggest battery drain by far. 20% per hour even on low brightness is well within what I'd expect, especially since the N4 has never been revered for its battery life.
Hi,
I did a factory reset. Random rebooting is solved now, but my screen still drains 20-30% each hour form my battery.. Do you know how to fix it?
Zorak950
Normaly my screen only takes lik 5-10% max in 2-3 days.. But since few weeks ago everything changed.. And battery life form nexus 4 was good for me 2-3 days is engough
sanajy210
