Nexus 4 Best Apps [28Dec - Xposed Framework, Gravity Box, XblastTools & AppOpsXposed]
Re: Nexus 4 Best Apps [21Mar - Google Keep]
SuperBeam - Easiest and fastest way to share large files between android devices.
Swapped out Home Switcher for Home Switcher/Manager as this app seems to function better.
Greenify - Safely hibernate the apps that always seem to be running even when you are not using them.
Is there another app similar to Touch Control where I can just slide to unlock the phone? Touch Control Free PGM Nexus 4 doesn't work for me and I would really appreciate not having to reach for the power button all the time. Thanks in advance.
Thats why it wont work for you.. You have to be rooted to do it.. If you are interested in rooting. Its very simple
Will it break my phone if I'm not successful? :-\
Rooting isnt too difficult and nothing should go wrong at all unless you somehow drastically disregard instructions and just do something random. Its pretty much straight forward.. There is a great guide in the rooting, roms and hacks section :)
Thanks I had a peek at that section but got deterred lol....I'll probably use that as a last resort. I saw a recommendation for the Smart Screen ON app so I might give that a try
https://play.google.com/store/apps/details?id=it.android.smartscreenon
Flash Player - Flash player plug in for Android. Doesn't work with Chrome.
Firefox - Alternative browser, works with flash player plug in.
Great thread was just looking about to see what good apps to download so having a look through this thread for some ideas :)
MACV23
