Nexus 4 Screenshots: Share them here!
Changed it up a little
Finally got it to work out with nova launcher
So the korean widget is not very sexy. Not sure yet I will want to continue with the folders in the dock.
Date widget: minimalistic text
https://forums.androidcentral.com/e...id=de.devmil.minimaltext&hl=en&token=blf09anz
Clock/weather widget: zooper widget
https://forums.androidcentral.com/e...DEsIm9yZy56b29wZXIuendmcmVlIl0&token=uAm1Hk6W.
Calendar widget: smooth calendar
https://forums.androidcentral.com/e...calendar&feature=search_result&token=XHF_o3Ij.
And in case someone wants to learn Korean ;-)
https://forums.androidcentral.com/e...ails?id=net.koreanwords.widget&token=Y3IZrX8F
Thanks so much for adding the korean, I'm learning as well!
Is that the live wallpaper? Is there a regular nexus 4 wallpaper like that, do you know? Anybody? Can't seem to find one .
That is the live wallpaper and it works great. Those with battery issues I have had no issues with excessive battery drain after installing it. Had a lot more issues with the weather channel app draining my battery.
My current setup..nothing too exciting
[/IMG]
redmercer
