Nexus 4 Screenshots: Share them here!
Quote Originally Posted by Camaihofer View Post
Im really digging the clock, notifictions, and "slide to unlock"
The "slide to unlock" is a Widgetlocker theme.
Yep. Slide to unlock is Widgetlocker. I got that theme somewhere on XDA
Clocks (both on homescreen and lockscreen) are using Zooper Widget
and lockscreen notifications are from missed it
I like minimal. :)
so is there a way to create multiple different themes and toggle between them? restoring a layout with nova doesn't really do everything.
Still playing around with mine there's so much to do on an android device
HD Widgets
Platinum Icon Pack
Nova Launcher
Still a work in progress as I've only been using the N4 for a couple days.
Launcher: Nova
Icons: Sphere theme
Clock on homescreen: BobclockD3
Date and lock screen clock: Minimilist text
Weather: Eye in the Sky icon widget
Launcher: Nova
Icons: Sphere theme
Having your Starbucks widget as one of only two active icons your homepage is the first sign you have a problem :)
I am pretty sure that there's a way to do that in Nexus 4.
<a href="http://www.njytouch.com">NJYTOUCH</a>
Yeah, bit of a coffeeholic :D and as they're is a decidedly dismal lack of quality coffee in Tampa, that's what I'm left with. I was probably one of the handful of people who actually did use Passbook on iOS and like having the onscreen barcode at the ready.
I actually don't have many icons on any of my homescreens but put the most frequently used in the dock (3 separate dock screens) and have large Android Pro Widgets (FB, Twitter, Calendar) and an Evernote widget. Definitely nice having options.
Where do you obtain that awesome Nexus logo there in the middle?
Thanks.
I don't know who you was referring to but Google Nexus logos or check previous pages in this thread. Once you have the logo you can edit the icon in Nova Launcher (if that's what you meant).
uOttawaGrad_22
