Nexus 4 Screenshots: Share them here!
Does TSF let you put your icons anywhere you like?
I would say for the most part yes. As you can see on my home screen, that icon labeled "magic" actually is a folder that I can pretty much drop anywhere on the screen.
Pretty simple but a nice little wallpaper I found today
is it worth $16? what can it do that nova cant?
Worth it, hmmmmm...It's different and snazzy that's for sure. If you have $16 to burn, why not. Some things are weird, for example, in Nova/Apex, you press and hold a UCCW and get the options that come up to resize, move to front/back, etc...you don't get that in TSF. Even though, you can put an icon on top of the UCCW and it works fine. I'll continue to use it for a while, it's working for me.
@badbrad can you tell us what hex code you used for your widgets and where you got the app drawer icon? Thanks
SF Launcher just downloaded it
I made the icons in Photoshop. I can make you some different ones if you need something. Try FF696969 for the color. I honestly just eyeballed the gray color.
Ok thanks I'd just like to have the app drawer icon and the browser icon you already showed in your screen shot
Here my first shot. Using nova prime. Wallbase hd wallpapers. Zooper pro and one more clock widget. Sphere theme icons
Red_Nexus
