Nexus 4: Wifi authentication error
Re: Wifi authentication error
Hi, I'd like to use your advice but can not find "Advanced settings" on my Galaxy S3. Where do you find them? Thanks.
I recently bought the nexus 4 and have been trying every single method to get the Wi-Fi to work-but no such luck. All it states is-'authentication problem'. It's security protected so I changed it to WEP but it's still not working! Please help!
Make sure you are close to your router when trying to connect, usually low signal causes this problem.
Try going to WiFi and then menu, might be there. Sorry I dont own a s3, you might have better luck in the s3 forum.
I am also facing wi-fi authentication issue after upgrading S2 to 4.1.2.
Once set to static IP , you need to enter an IP there ryt? what IP to enter?
Re: Wifi authentication error - Samsung Galaxy Discover
I have the same problem on my SG Discover, and I have a WAP/WAP2. How do I change it to WEP? is the password the same?
my phone is samsung galaxy grand and i want to connect to samsung galaxy tab 10.1 (P5100) tru tethering but authentication error occurred?what should i do?
i had the same problem, BUT it was because I logged into my router. once i logged into my router through the internet, it reset my password. so i had to go into my router settings and change the password again. hope this helped. :-)
Either this is a "feature" of enabling remote admin on your router or you need to upgrade its firmware. I've never heard of a router doing this.
Oddly, I have this error when I'm up in my room where signal is low, but as soon as I get close to my router, the problem goes away and I can connect with full signal. I don't know what causes this, but it's annoying. I'm a Nexus 7 user, by the way.
Then it's probably this Android bug: Issue 36993 - android - wifi no longer working in ics 4.0.4. The issue is driving me nuts too and unfortunately Google seems to ignore it since September 2012 :(
(Maybe you also want to vote it up a little bit in Googles priority rank with the star at the left of the issue title.)
how do i change the WPA settings?? I was using my house wifi and suddenly cant connect to it, when i tried reconnecting it says authentication error. I tried fotgetting password and connecting again but cant.
bought a new quattro today and had the same problem. changed my wifi security to WEP. Did a factory reset on Quattro. could connect.
Bingo!
Firmware update for my many WAPs worked for me.
Netgear WAG102 was recently purchased in bulk, but the firmware residing on it was from 2007.
Now our htc one's (android 4.1.2) are blazing.
I have the same problem on my SGS2 after upgrading to 4.1.2 - it is a known network, the password hasn't changed. It later connects to the wifi after a while. It doesn't help forgetting the network and reconnecting. It must be a bug on 4.1.2 - any solutions yet?
How can i fix the authentication problem of my L9 optimus with the wifi? since recently it stoped working and every wifi i want to connect it to it says authentication problem error.
I had the same problem with my wife's Galaxy S4: 'Authentication error.' I tried several things, reentering the WiFi password, shutting off and restarting her phone, no luck. I finally fixed it by resetting my router. Try unplugging your router, waiting 10 seconds and plug it back in. That should solve the problem.
This was happening to me at my workplace. I went to advanced settings for my work wi-fi and modified Dynamic IP to Static IP. So far this has worked me and I have yet to disconnect/unauthenticate. Nexus 4 user.
So far so good. Seems to have solved the issue. Tested in one of the areas that gave me the disconnect/unauthenticate error.
Ran speed test app and it did not drop WiFi and I got a 27mb download result. That has never happened in that area of my house before.
Many thanks!
This worked for me! Thank you so much!
hi i had the same problem wifi autentication error, i did all the things in this post and nothing! But, i found the solution in google play!!! Download wifi fixer, then restart your router and open the program in order to connect to wifi, in the last window found nearly wifi and choose your red, nothing more! Good luck!
Taylor Bag
