Nexus 5 wifi, Bluetooth and hotspot won't switch on
Voika
3
Hi,
I have a Nexus 5 running Android 5.1
Since yesterday my Bluetooth, Hotspot and WiFi won't turn on anymore.
Bluetooth just switches itself off again when you try to switch it on.
Hotspot just doesn't even let you switch it on, it just grays out when you click it.
And for wireless it keeps hanging on "enabling WiFi" but even after 10 min of waiting it's still not switched on.
I've rebooted the nexus several times already which didn't fix the problem. Also Google doesn't give many suggestions on this particular problem so I'm a bit stuck.
Anyone any ideas on how to get this fixed without reinstalling Android on my phone?
Thanks in advance.
Having the same problem. Rebooting and factory reset didn't work (running stock 5.1.1), can't find a solution online. This only started happening within the last 3-7 days. Wifi, bluetooth won't connect (frequently turn themselves off just after switching on) and hotspot simply won't start at all. LTE and 3G radios seem to be working normally. Never flashed any ROMs to this phone, it is completely stock and no drops, damage, etc.
If anybody found a solution I'd appreciate the heads up.
Nehasingh12
