Nexus 6P - Android 6.0.1 Rolling Out Starting Today
Re: Android 6.0.1 Rolling Out Starting Today
Anybody else not getting lte after the update? I'm on at&t
Edit: never mind. I restarted my phone, and it did the optimizing app thing yet again but just for 4 apps. Anyways my lte is back now.
I had the same issue, but mine didn't fix itself after a 2nd reboot. I had to clear cache from boot, then manually go into Preferred Network Type and switch from LTE>3G>LTE (tried before clearing cache and didn't work). Finally got LTE again.
Also my notification sounds got screwy again, had to reset my custom ones.
I'm on Verizon and having the same issue. My preferred network type is "Global"
I lost LTE after the update on T-Mobile. Restarted my phone and LTE came back. How do I check if I have band 12 though?
I use the App LTE discovery.... will tell you what band you are on and signal strength (and a bunch of other data)
I received the update last night. I'm using T-Mobile service on Ting.
I didn't notice anything changed with the Google keyboard, except the additional emoji. Did the looks of it change?
Still no update here... with Tmobile, tried to do it manually through the settings also
NO update here as well yet.....
Yep, still no OTA update on my 5X. This being my first Nexus, I was excited about the fact that I would get updates as soon as they come out. I guess I should have tempered my expectations.
So I switched preferred preferred network type from Global -> LTE/CDMA, which changed nothing. I then switched to LTE/GSM/UMTS which turned off all cellular connections. I quickly switched back to Global where it was back to 3G. Fustrated, I when back to LTE/GSM/UMTS and left it there for several minutes where I then went back to Global and bingo, LTE.
I'm on band 4 still. How do I get on band 12?
You get them much quicker than anyone else....but it's still a roll out, not instantaneous. Got mine last night.
Just testing out Android Central App. Sorry for unintended post
Strange that some don't have it yet. I just got the phone last night and it showed up immediately. Maybe because I don't have a SIM in it yet?
It just releases in batches. Everyone don't panic it will show up in time :).
It depends on your location and if band 12 is present in your area. The 6p seems to do a better job than the 6 I had before it.... The 6 would basically default to band 12 all the time. So far today when at my desk (Which is right by the window of our building) I am getting band 4.. but when I go down inside our building or to the warehouse it's switched to band 12 instead of 3G or HSPA+... With the Motorola Nexus 6 I was on band 12 at all times no matter where I was in our building....
gruptysh
