Nexus 6P Photos! Show us what your phone can do!
I just turned on HDR+ and my low light pictures have improved over 150%. I was getting a little worried at first but it's so much better now.
Took my pup to the park late night after I got off work last night.
Literally the only non-natural light was in front of us via the lamps as you can see and this was well after the sun went down. Very impressive.
http://i.imgur.com/LStbS13.jpg
This is afterwards. The table chandelier was dimmed very low and we have a small lamp w/ a 60 watt bulb (and shade obviously) about 5 feet behind me. Little blurry but considering the conditions, this turned out great. She's such a model :)
http://i.imgur.com/NVFhw4v.jpg
This camera kills it in the low light.
This camera can capture some truely amazing pictures
Downloaded manual camera. Been messing with the settings. My room has very bad lighting and right now its dark. Pretty pleased with the pic. Dont know why but something about it i really like and looks good to me. I need to get use to all the controls in manual camera and learn more other then point and click. For those who want to know. Sig P229R .357sig currently set up for .40 S&W because i haven't had time to reload. Rounds are some handloads i whipped up. 140gr Barns Tac-XPD's pulled from the low power factory loaded and reloaded up with a bit more umph. 1,460 out of a 5 inch pipe 663 ft/lb's
The quality of photos really great and very good.
But my question is : The quality of this phone will be the same and the same performance If I bought It from any country ?? I mean for example the camera will stay the same great quality as I can see here ??
Friend Of mine will buy It for me from Malaysia soon.
What's your preliminary review of the app? I'm thinking about it myself. Easy to use? Easy to understand? Any other details would be good. Thanks!
Easy to use if you know the basics of photography. If not it will take you some messing around to learn it. Its worth the $3 Just take some time in learning how to adjust iso, shutter speed and all that. Outside of that its a great app and will allow you to take a pic and save it as a .jpg as well as a raw file.
Out on a walk with the dog
Master zx
