Nexus 6P screen problem? Please give me some pieces of advice!!!
  • Start date Start date
A
AC Question
Hey guys!
I neead some pieces of advice really fast!
My nexus 6P seems to have really really bad viewing angles..basically even if i move it a little while i am typing, the keyboard color gets bluish.
Please watch this video (also please forgive the backround noise). This is my 6P. I know that the video is not of a very high quality (it was taken with my ipad 2) but you can still see the problem when i use the keyboard. It can also be seen when i try to reach the notification bar.
Here is the video:
http ://youtu.be/164m5oQu9yQ
(Please remove the gaps)
Is yours doing the same? Is it normal? Should I ask for a replacement? I am really curious if your 6P is doing the the same.
Best regards!
Did you post about this before?
Contact the manufacturer's customer support for advice if you are worried about your device.
Tfunz
