Nexus 6P's Google Now + Whatsapp Problem
Yea.... Somehow. Since all of the usual stuff has been to ruled out.... I went back to when you originally noticed it. I would say unpair the phone, or at LEAST turn off Bluetooth, and then reboot and try voice again
Posted via my Nokia 8210 from the inside of a Kitten.
Okay edited my mum's contact to call her "Danny". Same deal. Send whatsapp to Danny - You don't have an account for danny.
Damn... strike this one off.
OK...(good) That tells me that it definitely isn't a syntax error with the contact name, rather it's something with the content of the contact, or how it's interfacing with other parts of your phone..
Oh you refreshed your whatsapp contact list so that 'Danny' now showed instead of 'mom,' right?
Correct. Exactly as you said.
What's even weirder KillerQ... I changed my mum's name back from Danny to "Pat". Tried to send a whatsapp again, to "Mom" - guess what? It doesn't work anymore...
Reassign 'pat' as your mom with Google voice by saying "pat is my mom"
See if that refreshes the nickname relationship
OK, here's the latest:
- Send whatsapp to mom = You don't have an account for Pat
- Sen whatsapp to Pat = you don't have an account for Pat
Just tried the assignment process. Chose Pat..
Then tried whatsapp. No go still. You don't have an account for Pat.
Hmmm... Did you uninstall updates for Google Now and unpair the watch?
KillerQ: Nope I haven't uninstalled updates for Google Now. Wonder how far back this will take me. I'll try it now.
PS: Sent you a PM.
KILLERQ: Just uninstalled Google Now Launcher's updates. Also unpaired the watch. Then I tried the usual - no go still.
What changed now though is that Google recognises that Mum=Pat. So that part is back.
Sorry about that. My private message notifications never work properly.... I messaged you back.
Interesting... I've been having the same issue. However Google is very inconsistent, sometimes the contact I have an issue with works and then when I do it again it immediately stops working. I can't pin point why it works sometimes and not others.
PS I don't have it connected to anything.
Hey Guys
please keep the discussion public if you don't mind. I'm curious for a solution myself.
As for Mark, please try the following. That's the exact order of steps that worked for me:
- Tell google now to send a WhatsApp Message to a nickname that is not yet in use (!) - "WhatsApp to brother / girlfriend / whatever", make sure it's not assigned yet
- Google will open a dialog for you to chose which contact you want to map to the new nickname to. Don't (!) say the contacts name but instead click on the List and select the contact manually. Google will then properly map the nickname to a contact - at least it did it on my phone.
- Close every instance of google now in your task manager. Or just simply close all open apps or restart the phone.
- Tell google now to send a WhatsApp to the nickname you just assigned. Use the nickname, not the contacts name, e.g. "WhatsApp to brother", and see if it works.
I would really appreciate a feedback
Thank you
Nils
Hey Nils,
What you suggested will work - I don't doubt it. But I'm working with KillerQ at the moment to find out what the heck is really going on at a deeper level as I want a proper fix, not a patch. KillerQ reckons we're kinda close to finding the cause of the problem. Let's see what he says when he gets in later today.
Mine hasn't been working for the past 7 days. Previous to that it has been flawless. I don't think it happened after an update either.
What's the story with you guys? How long has this been an issue for?
Hi Guys
I have the same issue. I bought a new galaxy note 5(on Lollipop), four days back and the google now voice for whatsapp was working absolutely perfect. I could speak any name and it was able to send a voice message. Real smooth.
Yesterday afternoon I received the samsung software update alert for Marshmallow which I updated over wifi. Once the phone was updated to Marshmallow 6.0.1, the google now voice for Whatsapp is displaying the exact same problem as Mark and Nils. Surprisingly i can only send the whatsapp msg over voice to my mother. She is stored as "mother" on my contact list.
Look forward to any breakthrough guys
Thanks
Blake
Still no luck on my side guys.
We all know that assigning nicknames will work with voice. But so far no clue as to what is causing the issue.
Something must have gotten updated over at Google's or Whatsapps servers, which has stuffed the connection between our contacts and whatsapp. Considering all the different things I've tried, I think it isn't local to my phone. Nothing has changed between when things worked and when it didn't work.
Numbers are all formatted properly and assigning a nickname works fine - meaning it's not a number formatting issue.
KillerQ said that the link between whatsapp and Google contacts is messed up and he's right I reckon. Maybe if there's a way to refresh that connection. I've even tried logging out of Google Now... no go.
Here's what I found out so far, beside the fact that assigning a vocal nickname works fine.
I reckon you're right, there has to be an issue with the contact mapping between WhatsApp and Google. Probably not a local issue either. But an interesting point was, when I first encountered the problem I backuped my google contacts into a local file on my PC and then completely cleared my google account plus did a factory reset on my phone.
I first installed all the updates I was offered, both Play Store and Samsung Galaxy App Store apps. Then I started from scratch and I entered a couple of contacts manually one by one instead of just re-importing the whole backup file. As of that moment it would work for any contact as it should. Google Now would recognize the contact name no matter if a nickname was assigned or not. It didn't matter either where I entered the contact, google contacts web interface or entering contact directly on the phone, either would work. So I entered half of my contacts and tested every one of them - worked perfectly.
But once I restarted my phone, it stopped working again all of a sudden. Any contact I already entered refused to work and every contact I created newly wouldn't work either although I used the exact steps I did before when it worked.
Another odd thing was, when I deleted all my contacs in google, they kept reappearing as "ghost contacts" in the seach when I entered the first letters. I was able to fix that issue by disablind and re-enabling the "include private results" (German: Private Ergebnisse verwenden) in the google search options. Ghost Contacts were gone as of that point, or at least I could not search for them any longer. Intersting, all ghost contacts were marked as google+ contacts, although they were my private contacts and neiter me nor them were signed up for google+.
But still I reckon there has to be an issue with left-over contacts on the google servers that it tries to grab the contact information from instead of the actual working contact that is stored online or on the phone. My guess is that google first looks on its own servers for contact information, finds redundant or deleted contacts, can't figure out how to map them and finishes off with an error instead of looking further for acutally existing contacts.
As I said, just an educated guess but since manually assigning the contacts to nickname works, probably overwriting the automatic mapping process, but the automatic name recognition doesn't, that might be at least part of the problem. It doesn't bring us any further though since we cannot do anything about left-over contacts on googles servers.
I know a lot of text, sorry for that, but it's complicated to explain - especially with english beeing not my maternal language ;). Anyway, I'm stuck at this point but maybe one of you guys can benefit of my findings.
Thanks for your efforts and keep us updated
Once I find anything new I will let you know
Nils
"My guess is that google first looks on its own servers for contact information, finds redundant or deleted contacts, can't figure out how to map them and finishes off with an error instead of looking further for acutally existing contacts."
Nils: this might not be true because normal sms's work just fine. If it's about contact data on the servers, sms's wouldn't work. Right now it's only whatsapp that's the offender.
You're actually right, I'm sorry. In all my testing I haven't thought of trying to send a simple SMS.
alejandro109322
