Nexus 7: Screen Shots
Re: Screen Shots
Here's landscape and portrait.
Re: Screen Shots
Aha! Thanks for this - I didn't know how to capture a screenshot on my Nexus 7! Will give it a go and post here... (I've got some cracking LWPs...
Re: Screen Shots
LWP - Fresh Leaves. Clock & weather widgets - Fancy Widgets
Re: Screen Shots
Main screen
Does not work (was: Re: Screen Shots)
Hello,
I am a Nexus 7 16GB owner since yesterday and have no Android experience whatsoever
(coming from the Linux/Unix/Maemo side).
I tried to take a snapshot with "Volume Down and Power keys together." but it does not work.
Volume is going down but there is no sign or information of a snapshot.
Do I need some application for this?
Update says it is all up to date.
Thanks in advance.
Edit: I made the mistake that I did not press the two buttons at exactly the same time as shown
in this video:
http://www.youtube.com/watch?v=wOm5LceuKac
Works.
Re: Screen Shots
Cluttered, but it has everything I need. Using Ultimate Custom Clock Widget, HD widgets for weather, and Shadow Galaxy wp. Wish the "tasks" widget was less opaque, but I didn't really like the ui of "gtasks".
Re: Screen Shots
atleast you admit the clutteredness :D
Re: Screen Shots
Thought ide share my Notification Bar because of 2 awesome little gems I found:
1) More Dock space app allows you to keep app icons in your notification bar
2) Power Toggles allows you to keep up to 8 shortcuts to commonly used power settings which can save you space on your home screen
:cool:
Re: Screen Shots
Here's mine. Weather is Fancy Widgets.
Re: Screen Shots
And here is another shot when i feel like getting crazy and switching it up a bit.
Re: Screen Shots
Work in progress. I like things simple. Looking to add applications up both sides. Maybe :D
Re: Screen Shots
This is what I'm working with now. Its a bit bright.
Re: Screen Shots
All done. Love the uccw app.
Re: Screen Shots
One more.
Re: Screen Shots
OMG you're so WILD! haha
ANyways, what widget is the calender widget you got there...looks like the default one except it's transparent...?
Lol. Yes it's just the stock widget, I don't remember but maybe there's a setting or something to make it transparent? I just added it to my desktop and it was transparent already.
manjushree903
