Nexus Charger not fitting properly
krishnansasikumar
339
The turbo charger that came in the box with the Nexus 6 isn't fitting in tightly. There is a slight play when it's connected.
The charger fits the Nexus 7 slot and the Moto X pure perfectly though.
Same issue seen when I use 4 other chargers.
Is this something I should be worried about our is this normal for Nexus 6
Posted via Nexus 6 or Moto X Pure
It doesn't seat in as far as I am used to on mine either but i have had zero issues with charging
Mine did the same thing. Swapped cables, issue gone.
Then again, I normally use wifi charging.
When I plug in the Moto cable that came in the box, my Nexus never says "Turbo Charging" it just says Charging. Is this normal?
Mine too shows only charging, but it charged the phone very fast. So it should be turbo charging. Gets charged in just more than an hour.
I once forgot to take my charger on a trip and used my wife's Moto G charger. The phone took 6 + hrs to charge.
So yeah, it is turbo charging with the provided one
OK, mine charges in under 2 hours, so I think mine is working right
crayzeefoo
