No Google Wallet?
I'm wondering if anyone can post a link to the updated Sprint apk? I might be able to use that for my testing. The one I have just gets stuck at the "Setting up..." screen.
So I flashed Android Revolution HD 9 on my phone since the build.prop on stock Rom continued to switch back to the original version when I tried changing the model, name... After flashing ARHĐ, I was able to use MoDaCo toolkit to update the model, name... and set it to disable Wallet check, installed the Wallet app, launched it without running into the incompatible issue, but now I am getting the "Insufficient secure element privileges" error. I may try to flash back to stock Rom tonight and go through this again.
Progress, but not to a point where Wallet is up and running :)
I also have Android Revolution loaded on my phone. I updated the build and used the MoDaCo toolkit. Wallet at least starts but it never gets passed the setting up screen. I'm hoping that the new APK for the Sprint model will get us further.
On a side note, is your LED blinking even when there isn't any new notification? Mine is acting like that using the ARHD9 Rom.
Just paid for a sandwich at my local Wawa in Jersey with Google wallet. Sprint HTC One here. Worked flawlessly.
No, mine's working as expected. I haven't seen it act strange at all. Solid green on full charge, solid red on charging, flashing red on low battery, green on SMS and email (I think) and red on missed calls.
I think I found what caused the issue with the LED flashing: Power Toggles. I had to disable and reenable it.
With S-OFF achieved, hopefully someone will put together a ROM with Google Wallet installed and working soon for non-Sprint HTC Ones :)
freddieleo7
