NO ICS :(
I am not happy with Acer as well. I wonder how many people out there don't know about the update and will never get it.
I don't think it would hurt to send the letter and you may get an mra which you only have to use if you want to. Did the store promise ice cream sandwich in any way?
Sorry took so long ro reply, been ill.I did email the company I pur hased from.They said because over 30 days would not let me return
Ofcourse the only reason 30 days was because Acer kept saying you will get update,just wait. I told the company that but they did not care.
Btw, what is an mra? I figure if tje tab did not pick up his update chances are it will not pick up any in the future as well.
The company I ordered from gave me an 800 # to call to mail the tab to to be repaired.It does havd 90 day warranty.Unfortunately it os hard for me to get out at times.
Is your tablet working correctly yet since you did the update yourself?I surely hope so.
ICS finally arrived on my acer a100 today.Unbelievable.
Almost two months since the U.S. release on April 23.
Why doesn't Acer let their customers know it can take that long to finally get the update?
You would think they would want to keep their customers happy and possibly have repeat customers.Just wanted to.let everyone know.
So happy you got it finally! I never got mine to work properly so I haven't been using it. I looked into installing Flexreaper on my A100 but it seems complicated to me and I'm afraid to proceed. You can't just update it like you do with stock ICS. I keep putting it off, mainly because I'm still afraid of losing my data.
An RMA is a return merchandise authorization. It's usually a number that you get in order to track the return of your product back to the company you bought it from.
I now wish I would have waited for the upgrade. It would be much less of a headache.
Well, enjoy your ice cream sandwich!
I wonder if there is a way to put the tab back to honeycomb like it was before the ics.I just hate that thhis happened to you. I know on a reg pc you can turn the time back( so to speak) to when things worked better,
Have you tried researching for solution?
I think maybe I can do a factory reset to go back to Honeycomb but I'm not sure. Never tried it. One problem is though that all my applications have been upgraded to ICS so I can't use any new backups if I go back to HoneyComb. Sorry I didn't get back to you sooner! Very hectic days here. I think I'm going to take your idea and go back to HoneyComb this weekend and use my old backups. I'll let you know what happens.
If I do a factory reset will I go back to honeycomb? For.some reason ifs has made my tablet buggy and slow. I don't understand why, its completely stock and I've never rooted. Every time I open my browser it just force closes hc was much more.smooth and fluid
Sent from my SAMSUNG-SGH-I727 using Android Central Forums
If you are on Honeycomb now, a factory reset should take your android back to when you first bought it.
If you are on ICS now, then a factory reset will not revert you back to Honeycomb. (I mentioned you might be able to in my last post. I was wrong.)
Here is a site that seems to have all the A100 firmwares. (And lots of others too.) In case you want to try another version and see if it cleans up your bugs.
|-| Androonay |-|
Time for an update.
I flashed a different rom and it's only been two hours since I did it, but it seems to be much better than before. It's much snappier now and it only has a few annoying quirks. Like having to manually turn on wifi after a reboot, and also the cpu spikes now and then (hardly noticeable), but hey I can live with that. On the upside, my camera is no longer upside down as on the last rom and I can listen to music without having the screen on.
I also rooted my tablet, and unlocked the bootloader so I can finally create a decent backup.
Well what did I say before? I'm probably going to be dead last and I was right (I think.) lol.
I think I'm all set but I'll be monitoring this thread for a while.
godef
