Not too shabby on battery life
anon(9918034)
957
This isnt my daily driver, I have been trying to get more time on it. This is pretty solid battery life, current have mobile data turned off while I am on WiFi. Have played raid shadow legends a bit and social media apps. Made some calls and text a bit. So far I have zero complaints about this phone at all. Just opted into the Android beta program and waiting to receive my ota!!! Screenshot_20190607-213700.jpegScreenshot_20190607-213556.jpeg
Be careful - at 40%, you should either charge the battery or turn the phone off. You can get longer battery life if you use it down to 5%, but at the cost of a much chorterbattery lifetime. And with non-user-replaceable batteries, that costs.
Battery saver on will also give you a little more time. So will a solid black wallpaper. So will disabling Device Health.
Did you see ios next update will contain code which stops the charge when battery reaches 80%?
I've been quite pleased with the battery life on my 3a XL. My phone gets light use, so I can get over two days on a charge. Granted, my previous phone was a Nexus 5, which was notorious for poor battery life.
Wow talking about exaggerating.
Argue with Cadex. What do they know? They're only the experts in the field.
I see no issue with 5% just dont keep letting it deplete or let it get very hot often , from my experience with 5 % to 100 non issue on all my phones plus battery needs to be calibrated at 5 percent to to 100 once in a while. Your battery life is between 2 to 3 years max and then need replacing .
Great battery life
This isnt my daily driver, I have been trying to get more time on it. This is pretty solid battery life, current have mobile data turned off while I am on WiFi. Have played raid shadow legends a bit and social media apps. Made some calls and text a bit. So far I have zero complaints about this phone at all. Just opted into the Android beta program and waiting to receive my ota!!! View attachment 304110View attachment 304111
kiki2025
