Note 10+ Android 10 - Official First Impressions & New Features
Re: Note 10+ Android 10 - Official First Impressions & New Features
For those that use Samsung Pay with the bottom tab on the home screen with the Android 10 full gestures option, you'll need to swipe up from either side of the tab to get to the recent apps screen.
Also, with Android 10 full gestures you'll need to enable the bottom indicator in order to use the swipe left or right at the bottom to scroll through your recent apps.
Anyone know what the little dot notification is?
Anyone having issues with the phone after the update. My phone is crashing and restarting randomly.
Thanks I just tried it and it's just not the same as stock android 10... Thanks for the help though
Try edge gestures. I like it better then the good lock one handed+. I'm like you, I have been using Nova plus for 10 years maybe, I'm not leaving it. It is getting old that Google keeps blocking things, that's the Apple way, we don't have Apple for a reason.
I don't know if edge gestures will be any better for what your looking for, I like it better myself. Doesn't hurt to check it out.
https://play.google.com/store/apps/details?id=com.ss.edgegestures
OMG! The update currupted my SD Card...... Not sure how that happened. I wonder if it is because I encrypted it. I'm so upset.
Okay so here is a direct article from Nova Launcher explaining what is going on with the gestures... it's not a Samsung or Verizon thing, it's a Google problem
https://help.teslacoilapps.com/faq/gesture-navigation
After updating to Android 10 I cannot reply to a text message from the notification shade. I touch the reply arrow and the message itself but nothing happens. I'm using Nova if that makes a difference. Anyone else notice this?
I use Nova and it's working for me
Is there a way to change the way you view the tiles of recent apps or are we stuck with the scrolling sideways? I prefer having them stacked
Thanks. It's only on the lockscreen that it doesn't work. The phone is unlocked by facial recognition when I tap the reply arrow, but it doesn't open the reply window. If I extend the notification and hit the Reply button, it opens the message app (I'm using Android Message). If I unlock to the home screen and extend the notification shade, the reply arrow works as normal. It wasn't like this on Android P, I'm kinda bummed to be honest.
It rendered my Ring app next to useless; wiped out the Live View feature. My other Note10 Plus through Xfinity hasn't been updated and Ring is working fine on that phone.
thattoiletguy
