Note 10+ Android 10 - Official First Impressions & New Features
I don't think anyone has mentioned it (but sorry if it has been), but one thing I am really liking is how they have separated notifications now. Not sure if Samsung thing, or Android thing - but when you pull down to look at your notifications, there is the regular notifications and then there is a "Silent" section. The notifications that are not categorized in the "Silent" area are put on top before that section. This way, you can concentrate on those notifications that are important to you at the top. You can change the categorization by long pressing any notification and selecting "Alert" or "Silent". I love this because I do have some notifications that are not as important and it was a mess with everything integrated into a single list.
That's a good one.
Has anyone had any luck with the developer setting to chang icon shape and accent colors? I've changed the icon shape but only certain ones change, and the accent color does not change at all. Guess there's a bug somewhere🤷🏾*♀️
Yeah didn't pay attention until you mentioned it .Screenshot_20191228-010233.jpeg
I noticed it, and it's nicer for sure, but I disable most apps notifications anyway.
I have the Note 10+ and I just got the update this morning. I have AT&T. Now my home screen has overlapping symbols at the bottom of the screen. Anyone know what they are? I can still use the buttons like before. Thanks!
Looks like a screenshot over the actual screen to me
What do you see when you turn the soft keys off and go with one of the gestures options?
Has anyone else felt the need to factory reset after the update? Does this still help at all with a clean slate or is it not necessary?
It's up to you really. I didn't do one and everything is working as it did before. I did do a cache wipe though. Again it may not be needed.
Has anyone else had a problem with ringtones and notification sounds since Android 10 update? My Note 10 + will not make any sounds for text messages and will not let me select any ringtone other than the stock AT&T one. No matter what I select it defaults to the stock one, and absolutely will not make any sound on text messaging. I already did a wipe cache and a factory reset. and also made sure that do not disturb is off and volume at max. Really hating this update. Also, edge lighting no longer works either.
Being stuck on November update doesn't surprise me.
The fact that I haven't sold it does. lol
Did you try safe mode ? See if notifications work for message app?
Yeah. I finally figured it out. I had that screen saver for 2 days before I noticed the overlapping symbols but them must have been there the whole time. It is because it's a screenshot. Thanks.
Yep, doesn't work in safe mode either. Going to place a call to Samsung tomorrow, this phone has had some strange behavior Fort past month and the upgrade to Android 10 just pushed it over the top.
kitlis
