- Feb 6, 2017
- 99,060
- 15,754
- 113
That's about the only time I want AOD on, that and if I have notification. I have a nice app that makes it so the AOD is off unless there's notifications or charging.They also added the AOD option to turn off when battery shows charging on Android 10.
Checked the settings after my post... Are you referring to the actual AOD, or the charging time listed at the bottom of screen?
I seen that, but I read it as option to turn AOD off while charging.I mentioned the charging at the bottom
Either way, it's useless setting for the people that use their phones as alarm clocks, as the charging time is still displayed if the AOD is displayed.
I understand that...I, like others use the phone as an alarm clock and WANT the AOD on for the time, like normal alarm clocks, and the display at night is very dim, so it isn't lighting the room up.I use my phone as an alarm clock and this setting is very welcome. I have AOD scheduled to turn off at night so my room is dark. Before this new option, the charging status would still appear at the bottom even if the AOD was turned off (by the schedule) and would light up an otherwise dark room. I can't stand LEDs and other things lighting up my room at night, so this option to turn off the charge notification when the AOD is off is a great feature.
I'm with you on the custom camera selections and good lock. Good lock is a Samsung app, why can't they update that at the same time they release the new OS.After using Android 10 for a few days now, It's been stable with no issues. I'll break down some of my likes and dislikes.
Like: The new camera layout. It allows just display the modes you use most.
Like: OneDrive integration with Gallery (on caveat I'll explain in the dislike).
Like: The overall smooth operation.
Like: New gestures (unfortunately, Microsoft Launcher doesn't support them at the moment).
Dislike: OneDrive integration is only available IF you save your photos to internal memory. Not a deal breaker, it would be nice if it syncs with the SD card too.
Dislike: Good Lock not supported...yet.
That is all for now. As I play with it more, I'll update.
Are you sure it wasnt already corrupted?OMG! The update currupted my SD Card...... Not sure how that happened. I wonder if it is because I encrypted it. I'm so upset.
Good question , technically they TMobile now so yes , just joking ..i haven't heard anyone say anything.ANYONE WITH Sprint get Android 10 yet?
No, but I keep checking.ANYONE WITH Sprint get Android 10 yet?
Is the official Android 10 update still being rolled out in phases? I'm still on the most recent beta version, but there's nothing there when I check for software updates. I'm on T-Mobile. Thanks!
On the subject of device care, has the option to see how long you have been off charger been removed? I can't seem to find the setting when you want to test your battery duration.I don't like either the new version of the device care, I find it too complicated for the battery usage.
