Note 10+ One UI 3.0 beta on the way
I have unlocked note 10+ on T-mobile and don't see in samsung members. Do I need to check under particular section?
You will see it in the little swipe news box as soon you open Samsung members app at very top.
Tried installing beta on US unlocked. Stuck at Samsung logo for more than half an hour. Any suggestions?
Tried recovery and clearing cache partition. Also restarting holding volume down and power button and draining battery and restarting. Nothing worked :(
Any help please.
Yes, switch phone off, plug into you pc. When charging shows hold power and volume down. Worked for me.
What exactly happened?
After hitting install it reboot and you seen android bot showing progress bar up.to 100% and it started and stuck at Samsung logo?
Yes, that's correct. After installation, it rebooted and stuck at Samsung logo.
Can u get into recovery?
Or go to smart switch there's a new update for it on pc version, see if it ask you want go to stable version ?
I having the same issue getting stuck at the Samsung Logo, I've tried powering down by holding the power button and the volume down button but it keeps going in a loop and won't enter recovery mode no matter what button combinations I do. I tried to install Smart Switch but it won't recognize the device.
I forget smart switch only recognize when phone on .
Ok guys > you'll need to flash stock firmware through odin
Whatever you do don't sign out /un- register from beta in Members app , once you flash the stock firmware and choose update again it will show up beta 11.
Master zx
