Note 10+ One UI 3.0 beta on the way
I forget smart switch only recognize when phone on .
Ok guys > you'll need to flash stock firmware through odin
I was finally able to get into recovery mode and do a factory reset. I backed up everything with Smart Switch so it took only an hour to get everything back the way I had it.
Unlocked note 10+
Ok , here is a guide
This is the steps :
Windows computer needed
Latest Odin can Google it from XDA Forums and download the latest should be Odin 3.14.1 / and Frija tool or samfirm (i usually download both)
Download samfirm v0.4.1 tool and frija, extract it with 7zip.
You will extract files for Odin prince comsey 3.14.1once download with 7zip and will do same for firmware with 7zip .
Put your model number then region and select check for updates , then download the FIRMWARE , extract the FIRMWARE with 7zip.
There will be 4 files after you extract the firmware
BL
AP
CP
CSC
Each of those files will go in Odin when you open to the corresponding slots
BL
AP
CP
CSC = Home CSC File
Last slot don't put anything
CSC USE HOME CSC FIILE TO SAVE DATA /THIS ONLY GOING BETWEEN CARRIER FIRMWARE OR IF YOUR ON UNLOCKED GOING BETWEEN UNLOCKED FIRMWARE
If you going from carrier to unlock firmware keep regular CSC not home CSC and do a back up it will factory reset the device.
connect your phone with cable to computer , once the files are in its slots hit start, once done you'll see pass in Odin and it will reboot
*Make sure you put phone in download mode
*If dont see your phone connected in Odin change cables or ports in computer .
*Never disconnect the cable in middle of flashing.
I logged in to members app to check if I can download beta but i see a message that "star wars edition isn't eligible for beta"
Choosing TMB or CSC downloaded exactly same firmware through Frija.
Sorry, I meant choosing TMB or XAA downloaded exactly same firmware through Frija
TheGreatApe00
