Note 10+ software update/still oct
I had to do a factory reset after I flashed my factory unlocked with T-mobile software before I could install any updates.
That's something I didn't want to hear.... It takes so long to restore... But I guess it's worth a shot
So I have the Note10+ factory unlocked version flashed with T Mobile. I keep getting this message. A little confused as to who will push my updates samsung or T mobile
I have the same factory unlocked note + with t mobile flashed and get that message. I connected my phone to smart switch. I was doing a backup. Smart switch gave me message
A new software version is available. So I downloaded it
It depend. When you flashed the T-Mobile firmware on unlocked phone. Did you flash home.csc or just csc? If just csc then you should update fine. If home.csc then you need factory reset it.
Yeah I always like to flash CSC for clean install , home CSC will save data but like nuangel2 said update through smart switch you'll be ok
Smart Switch does help a lot, but there's still an hour or two of manual restoration to do. I have to decrypt and later re-encrypt my SD card. A number of passwords don't carry over (even using Samsung Pass). And if I recall correctly, it's necessary to re-register fingerprints, re-verify Samsung Pay credit cards, separately restore Secure Folder items, reset and restore my Samsung Gear watch to pair it with the newly reset phone, and probably a few other things.
So I'm grateful that the last few times I flashed an update with Odin, I was able to use HOME_CSC and it worked just like an OTA update. I would only do a clean install if necessitated by an emergency.
Yeah for some it's a pain to set everything up, it's a hit or miss when I've flashed between carriers and unlocked most times good but been some hiccups had to start clean .
So I did a master reset and boom! Did not to a reset.., but it worked
Updated
Got a 2nd update as well
I did not have to do any of that. I have a password saver roboform. I don't encrypt my SD card. And did not need to re-register my fingerprints. It was easy.
Got a Unlocked Note 10+
I'm on Nov 4th 2019 update
version n975u1uesasj8/
Security update
Says my software is up to date.
maryhurst515
