Note 20/Note 20 Ultra accessories discussion.
Received 3 cases so far:
Spigen Tough Armor Designed for Samsung Galaxy Note 20 Ultra 5G Case (2020) - Black
ESR Metal Kickstand Case for Samsung Galaxy Note 20 Ultra Clear
SUPCASE Unicorn Beetle Pro Series Case for Samsung Galaxy Note 20 Ultra Full-Body Rugged Holster & Kickstand Without Built-in Screen Protector (Black)
The Supcase is HUGE! Could probably run the thing over with a tank and not get a scratch on you device. I haven't used a holster style case in 20 years - clips to belt kept breaking. Doubt if I'll keep this one.
How big is the Supcase compared to the Spigen Tough Armor? Like thickness wise and width? Is it a little larger?
I can fit the Spigen case inside the Supcase. It also has a little bit of weight to it. May keep it for those times I'm hiking through the Himalayas!
Oh wow.. yes that is why I am looking for a big rugged case as well for certain occasions! Thanks - I might consider this!
Ditto. I have a black and a blue for my Note 10+ 5G. I always use them. No other cases matter to me. Ihope they make a blue for the Note 20 Ultra as well. I received my black for the Note20 yesterday.
I should get mine today. I haven't used one in a while.
Samsung clear protective case to show off the awesome color !!
I'm waiting for the same case in white to be delivered today but I ordered the black as well to be delivered tomorrow. It looks like a great case.
These got here this morning. Phone will be here any time now.
So you’re actually covering the Camera holes...mine has holes in the protector but it’s black and I want clear. I was afraid to cover the actual lenses...
Yall! These Buds are winners! I popped 1 in and did the heavy metal head banger moves...that bud stayed put. Imma believer in the beans!
I didn't think about that. I will see if it makes a difference and swap it with something else if need be. It's just a whole lot of glass!
If you see firmware update for buds live don't update.. My left buds now doesn't connect at all, reset doesn't work as well. Saw couple of people on reddit with the same issue. So just FYI.
Thanks for the heads up!
mikail
