Note 4 action memo has no tack!
I have run into the same problem. Even after uninstalling nova launcher, the tack for action memo is still gone from normal touchwiz. For now, the only way to have the tack back is to have touchwiz as the default launcher without uninstalling nova launcher. If I don't want nova launcher on my phone, is there a solution to the problem?
edit: Never mind, I figured it out. You just have to set touchwiz as the default launcher again after uninstalling nova launcher.
I have the same problem but never used any launcher. Anybody found any solution? Any idea of the packages involved on the handwriting-to-text functionality? my feeling is that the problem is on that packages. I am using android 5.1.1.
I have a similar problem only had my Samsung note 4 for a week no launcher addons. My problem is I have no text to action feature I too saw this feature used on you tube and its not there on my phone. Its the Icon at the to left and to the right of the pen and eraser icon. I should have a circle of dots and it is designed to have 5 actions to convert a text phone number and either use it to make a call or too add this number to the contacts list. It also does the text to email and internet etc. Works on my sons note 4 fine (and he doesn't use it) but its not there on mine and I am always writing notes down (short term memory problem) any sugestions
thattoiletguy
