Note 4 and your car, Compatible? Yes/No?
Works fine with my 2014 Ford Fusion My Ford Touch and in my 2006 Mustang with the Alpine IVN w910 head unit.
Sent from my Galaxy Note 4 using Tapatalk
Do you use the bluetooth streaming for music? I have the same set up and when I set it up first I had both music and text showing next to the device. Shut car off and next day all I had was the texting part no music symbol.
Have u had any issues with the "bluetooth share stopped working" error message with the N4? I know on my S4 the 4.4.2 update broke my ability to stay connected to my bluetooth. Whenever I respond to a text message after receiving it thru my car, the bluetooth share error comes up and disconnects my bluetooth. It will automatically reconnect but when I am streaming music it is quite annoying.
I can not get it to connect to my car scion tc. S4 worked great previously.
Mine worked great with the Note 3, now I have the Note 4 and I get no album and song info on the screen of my radio. Bummed :-\. 2012 Mazdaspeed3
what kind of errors do you get? Just unable to connect/unable to find errors? The reason I figured I'd create this thread is so we could get a decent registry of what works and what doesn't but to see if we can help each other out.
Had no problems setting it up with my Lexus RX350 hands free system. Works just like the Note 3.
Mine will connect once in awhile but I keep getting an error saying device full and then disconnect. Any ideas?
It does not connect at all or recognize. It says bt connection failed
I have a 2010 mustang GT with ford sync navigation system and it works perfectly I even get texts via on screen and it will read them out loud and I can reply on the fly.
Posted on T-Mobile Galaxy Note 4
Ditto on everything said above. 2010 F-150. The text was a nice surprise because my GS5 was not supported for texts.
My '14 Kia Optima works. Even the Uvo online app works, which on my Note 3, it would report that it wasn't 100% compatible.
Sent from my SM-N910V using Tapatalk
I used the "media" button on my stereo today and it had no problem reading my Note 4 (Kia Optima). The song advance steering wheel controls also worked.
2014 Mustang here .-.. Works perfectly!
Sent from my Samsung Galaxy Note 4 using Tapatalk.
2013 BMW 3 series is perfect. 2010 VW Jetta is perfect
Sent from my SM-P900 using Tapatalk
2014 ford edge limited here and everything works flawlessly. Through sync and Bluetooth radio
GeekGlasses67
