Note 4 - Post your battery life screens and info
How can u get these stats ?
how high is your brightness ?
i am using greenify donation and try everything to increase my battery life but i could get 5 hours sot on the MAX normaly when i go to bed i have 40% left with 2 and half hour of SOT
I get 3.5 hours SOT, I'd be lucky if I got 4.
24 hours in on lolipop.
Unplugged from charger 5:1 5pm
Posted this at 3:05am
25% remaining after 9ish hours on battery.
6 hours 15 minutes screen time.
Is this better or worse than you were getting before Lollipop? I feel like mines slightly worse after upgrading
I just noticed something, if you look at the "Mobile Network Signal" bar graph in the attached screen shot, there's an awful lot of orange there. I remember reading somewhere that red means no signal, anyone know what orange means? Could this be affecting my battery life?
Wait, so there's a bigger capacity battery out there that's the same size as the factory? I'd sacrifice NFC if that's true
It's pretty common for third parties to manufacture aftermarket batteries for these devices. Here's a link for the "acesoft" brand I got on eBay but there are others around also and depending on your model number...
http://pt.tapatalk.com/redirect.php...3.TR0.TRC0.Xacesoft+note+4&sqp=acesoft+note+4
Sent from my SM-N910T using Tapatalk
It's pretty common for third parties to manufacture aftermarket batteries for these devices. Here's a link for the "acesoft" brand I got on eBay...
I'm only seeing batteries for the Galaxy Note Edge, would those work in the Note 4?
I'm getting a little more drain on the battery, nothing I'm worried about. It's not bad. I'm not a power user. I have been using more since the update too. I'm still able to get through the day with it no problem. Today didn't use too much.
If you scroll down there's the ones for note 4, and it should work if you just search your model number and "battery" or "note 4 battery"
I was streaming ultra music festival all day with twitch
Ok that's out of control, 6 SOT with 49% battery left? That's already over 2 hours more screen time than me and you're barely halfway through your battery!
There's gotta be something we're missing here, I see people getting 3-5 SOT, but then there's people doubling or almost tripling that! HOW?!
We gotta solve this -how many people getting over 5 hours SOT have Sprint? How many are using a micro sd card? Anyone super knowledgeable on reading all the bar graphs and stats in the power section?
Agreed, please, more information as requested.... Carrier, etc...
AT&T, lollipop 5.0.1
Inserted screen on time below screen % using picsay pro . Auto bright, Power save on, Wi-Fi and data network on, Bluetooth on and connected to Gear S.
I usually get better than this but I've been in craptacular reception most of the day today.
i got great stats this weekend !
I juiced my phone friday night, and i did not have to charge it for the whole weekend !
After the BOC3 update i removed greenify and some system apps, i never use power saving and my brightness is around 40%.
no more concerns for flashing a custom rom, this build is awesome !
so is it really true that the micro sd card drains battery ?
i have a 8gb cheap sd card inside my phone but there is nothing on it..
SD does not drain battery, unless you are constantly using it, same as if you was constantly using the internal memory. I get insane battery time and I have over 70 gigs of files on my SD..
Oh oops sorry guys, of course I have the 6500mah battery, I don't know why I didn't mention that.
I definitely recommend it. I get 10 of sot and it's not that much thicker.
http://tapatalk.imageshack.com/v2/15/03/29/3738674f28e0e30fb2fad17438e98638.jpg
http://tapatalk.imageshack.com/v2/15/03/29/837629b26366f912b76d07fd7e55ac5d.jpg
If I were to use power saving mode I'd get around that too, probably more actually. Do you have power saving mode on all the time? I don't see your screen in gray scale mode
I think most everyone (including myself) is assuming what you post is without any power saving modes or extended batteries unless specified.
Qtinopu
