Note 4 sd card issues
armin80
15
Dear all,
I have note 4 but I am facing issues with the SD card ,once inseted in the phone it's start freezing, restart and hangs.
Sometimes work on sd card without any issues just for 1 hour and when I play song after 15 seconds the song stopped playing .
I have tried 3 SD cards brand new San disk and Toshiba exceria 16 and 32 GB and still facing same issue .need your help forum.
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,973
5,282
113
Do you keep putting the same data on each card? If so, then one of those files might be corrupt (or malicious).
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,973
5,282
113
It might be due to some app that's on your Note 4 that isn't on the Note 2. Unfortunately, it's difficult to know for sure.
IAmSixNine
3,157
72
If you can run the note 4 with no SD card, then put in an SD card and get issues, i would try to boot phone with a card, then use the phone to wipe/format the card and reboot and see if that solves the issue.
VirginiaMaeHandy
