Note 5 Battery life thread
I've only been on the new update for a little over 5 hours, but standby seems to have improved.
This is while mostly idle at work, previously that line was noticeably steeper.
Just got home and didn't have no time at all to use my phone at work today standby idle is fantastic as you can see.
Still great battery life no tweaks or any special apps at all just disable bloatware nothing else and was playing YouTube for 1 hr and 38 minutes on my second Note 5 .
Ok, this is after the TMO update yesterday and using the battery optimization, but the day is just starting.
Well it is kind of like not disabling too much where my phone is concerned.
I disable some bloat, but if I disable a lot, it shoots my Android OS up and drains my battery.
What exactly shoots up?
I disabled 27 items on mine (AT&T) between the Carrier and TW. Basically if I didn't need it, want it, or use it, I killed it.
I am not seeing any huge battery suckers. From an app perspective Android OS is low down at 8.7%.
My Android System and Android OS shoots up and becomes the number 1 and number 2 things using my battery and my battery won't even last 10 hours.
Hope someone can help me. The past two night I have suffered from about 50-70% battery drain through the night. This is within a 7 hour window. Please let me know any details needed to help troubleshoot this matter. My phone is also not rooted.
Thanks
I have crazy idle drain at night as well. I have the verizon n920 and have the latest update. I have even turned on airplane mode to see if it was the signal that was causing the drain. from 100% to 75% in 4.5 hours.Screenshot_2015-11-02-06-36-48.jpgScreenshot_2015-11-02-06-36-43.jpg
I have tried everything. I disabled most things on Package disabler pro, have turned off autosync. The only thing that I have turned on is wifi, just so I can use whatsapp. I am not rooted, and dont plan to at the moment.
EDIT: Location is OFF, Power saving mode is ON, there are no themes, I use greenify.
I have crazy idle drain at night as well. I have the verizon n920 and have the latest update. I have even turned on airplane mode to see if it was the signal that was causing the drain. from 100% to 75% in 4.5 hours.View attachment 204427View attachment 204428
Try enabling everything in package disabled pro and only disable stuff through application manager.
Still going with my battery after the update yesterday and the app optimization yesterday. It is very disappointing that Sprint disabled this feature because it is really making a difference with battery.
most things are disabled thru the application manager as well, such as all the apps that I dont use (instagram, etc.). There are some system processes with the android icon that have been running since the phone has been on today, but I dont know what will happen if I disable those.
This is my final before I recharge.
kctraci1
