Note 5 Battery life thread
i been writing down my battery info down every time i go to charge it and hoping to find a way to get it to last long enough for me through out the day cause Thursday is my last day to return or exchange it but i know there isnt a phone out there that can give me the performance and awesome screen like the note 5.
I think GSam only calculates the actual WiFi toggle being in. When my WiFi is set to be off when sleeping, GSam shows it never goes off, but my phone tells a different story. When I turn on the screen, my WiFi symbol pops up and I get a notification with the network name I just connected to.
mine never does that. I Click it on and the Wifi still shows on and not connecting.
With all the talk about heavy moderate or light use I'm starting to understand one person's definition of those terms is different than others.
There are some people that have their phones for just personal use. They read FB and other social media. They listen to music. Might watch a little You Tube some gaming etc. I'd consider that to be light to slightly moderate depending on SOT. BUT if they dont get a lot of work related email it changes things.
For someone like me this is my personal and work phone. I get a LOT of email daily and answered many back. I am receiving upwards of 50-60 emails in a day and responding to half of them.
I am texting frequently when not in the car and when in the car on the phone hands free with plugged in ear buds.
I do use FB and probably check it hourly for 5-10 minutes. I check Twitter occasionally during the day as well.
Most of my use in battery is email, text, reading some articles relevant to work, and pulling up video links sent to me. I'll use the AC forums app as well as feedly and the WSJ app.
To me when you're using it in this manner it uses a LOT of juice apparently.
That's heavy use in my opinion. Always reaching for it throughout the day. And I don't have an office I go to. I have a home office so I'm not restricted from when I use it and how I use it.
I'm getting with Heavy use in this manner about 9-11 hours max and maybe that's what I should expect despite my iPhone 6+ under the same conditions giving me 12-15 hours.
Side note: I shut off WiFi to the phone and noticed MUCH better battery life using just 4g or 3g because my signal is not great. To me that's the opposite of what SHOULD happen.
Maybe with an update this will change. I'm on Verizon BTW
I'm with you on this. I feel it's a bug. When I'm on wifi I'm definitely burning through my battery a lot quicker than if I was just on 4g. Very opposite indeed.
Sent from my SM-N920V using Tapatalk
So I was using Outlook for email as well as Gmail. During my battery issues I decided to go with just Gmail and I deleted outlook. I'm wondering if anyone knows if having two different email apps would hurt battery at all.
I prefer Outlook for all the extra features it offers. Any idea of an impact on that?
I just dont get why your backing up the note 5 so much like anything we post about it being bad you always dont agree.....We dont use the same apps and settings as you so you cant keep saying the note 5 battery is good and i can link you to about 8 reviews i watched and they state the battery isnt that great and is a downside of the phone.
I'm not going to lie about results I get.
Also, as I said, I checked a lot on this phone before it was released and the testing that was done. Just because you didn't see all that doesn't mean it wasn't there.
I can link you to just as many, that think it is just as good and just as many that think it is worse, on here.
I've run both before and not had noticeable issues.. But I don't have a Verizon variant. I'm not having the WiFi standby increase and I also am not dealing with a low signal.
This is a really light day at home with a good signal. Even with light use my work apps still draw quite a bit of the power.
Wifi off all day
Wifi off all day
//images.tapatalk-cdn.com/15/09/07/98a11d8bfb4d2c8107881278b4d5fcfc.jpg
Your held awake time is pretty high. Almost like your phone isn't sleeping. I would run wld
http://forums.androidcentral.com/sa...71286-wakelock-detector-no-root-required.html
For comparison, look at mine
Sent from my Verizon Samsung Galaxy Note 5
Same here , can't seam to be able to shut off wifi scanning, or even shut off when sleeping
Everything is off ...but it keeps going!!
T-mobile 64gb note 5 here
That's weird. On my Verizon version, I shut off wifi and wifi scanning.
Android system consuming so much battery but the phone most of the time is in standby mode=/
*Tried to wipe cache seems like not working
Sent from my SM-N9208 using Tapatalk
Yes so did I but do you show in GSM that cell and WiFi are the same?
He doesn't use WiFi.
Again, I think GSam reports the WiFi just when the toggle is turned on. Mine goes to sleep and GSam reports the WiFi as always on.
Looks to me like it's mostly screen on doing the consuming. Not the system.
Sent from my Nexus 6 using Tapatalk
27% drain in 3 hours and only 48 minutes screen time isn't that good. Something is draining it
heritagevines38
