Note 7 Screen shots
Status
Not open for further replies.
Can you provide a screen shot of the one you selected to put an image on the AOD -- I cant find it under the clock selection
You can also use Smart Select. After your image is selected, at the bottom, third icon from the left is the AOD icon. Select that and it will put it on your AOD.
I just figured it out. you have to be on the latest version of AOD to have the last clock with the ability to add an image. I had to go to Setting - Display - AOD - About AOD - Update AOD
After the update, the clock with the image capability was available to me.
These are all really awesome! I haven't changed my wallpaper in three phones, unfortunately. And I go minimalist always on my home screen. Not even a clock widget.
I don't think I'll do too much tinkering with my homescreen this time around.
Constantly using Themes and I like this new feature on my note 7, it allows you to change the wallpaper or icons if you don't like some parts of the theme, previously I was using Nova launcher but I like the new customization with themes
You can still use Nova with themes.
Status
rose1988
