Note9 compatible with Note8 Gear VR?
You'all sure that's not the promotional headphones? I also have a package coming today, but I assumed is was my promotion gift.
What do you bet this adapter they are sending you folks is identical to the one you already have...
What adapter would that be? I don't have a USB C to USB C, and the one in there currently is simply too tight of a fit for the Note 9. However, I won't rule out you may be right, I just don't see how I already have an adapter that would work. Or perhaps that's exactly your point. DOH.
I already received my headphones so this is the only thing I'm waiting on from Samsung.
It's not. There IS a new adapter to accommodate the thicker back of the Note 9 and this is what they are sending people for free. It works in the current Note 8 VR but it's a pretty tight fit and you have to push it down quite a bit for it to make a good connection.
My adapter directly from Samsung was just delivered, once I can get home and get my hands on it I will do a side-by-side comparison with the new adapter and the old Note8 adapter.
The Note9 is thicker than the Note8, so the adapter needs a little more space so you don't have to jam the phone in too tightly.
Hi,
Have you tried this with whitestone dome. Will there be enough clearance to not pop the glass up?
In the Note 8 VR there seems to be enough space for the front of the device that I don't think it would interfere with a screen protector but I don't use a SP to be certain. It's the back of the Note 9 that fits tightly in the USB C connection.
Not sure why, but I actually received 2 Note 9 adapters and yes, it is different for sure because I wasn't comfortable trying to jam my Note 9 into the existing adapter. This new one (or two in my case) from Samsung is definitely made to fit.
Taylor Bag
