If you tap on the hour this watch will show you the hour in big numbers and with a maximum bright to see the time in direct Sun Light.
If you tap on the weather forecast, the forecast will be refresh.
If you tap on the weekday you will access to the notifications screen.
If you tap on the month receiving notifications will be enabled or disabled.
To change from 24 hours clock mode to 12 hours clock mode tap on bottom right corner.
To change from showing the battery level tap on bottom left corner.
Tap on Top Left Icon to go to previous notification.
Tap on Top Right Contact picture go to to next notification.
Tap on Top Numbers to close this screen. x
