Nova launcher
How do install this in the root directory to keep my widget drawer? Thanks!
What battery widget is that circle on the bottom?
Beautiful Widgets
What like the moto key set up I'm running. This set up is just like the moto phones. Even search can activate voice search
is there a way to get the "menu" button in the bottom bar with nova? i've seen some people with it in the screenshots thread.
Right now it seems the only stable launcher is the stock GN. Nova has been crashing like crazy and Go hasn't done their ICS update yet, launcher hasn't update since may 2011 and ADW isn't ready for ICS yet.
Sent from my iPad 2 using Tapatalk
I just downloaded nova and like it so far. I'm new to android but have been loving my nexus.
I also downloaded the app homesmack from the market. It makes it easy to switch back and forth between default launcher. You guys might wanna give it a try if you haven't already
I've been using Nova for almost a week now and have yet to have it crash. There must be a conflict with a specific app that causes some to have FCs with Nova. Fortunately I must not have that app installed.
is there a way in nova launcher to hide the labels for apps? i loved that on launcher pro. can anyone also tell me if they've noticed any performance issues with nova on GN? thanks
I'm using Nova on my unlocked rooted Nexus running AXIOM 2.3 and have 0 issues with Nova. Runs great and no crashes :)
Nova does have the option to remove the app labels.
Yes. Nova Settings > Desktop > Label Icons. Uncheck this box and the icon labels on the home screens will be hidden.
I am running Nova beta7 on AXIOM ROM 2.3 with absolutely no issues at all. No crashes, no force closes. No reboots. No issues at all :D
Anyone have an efficient method for making icon images, you choose using nova launcher, have invisible backgrounds?
mostafamu
