[Odin-EC05] Froyo EC05 Prerooted/CWM v2.5.1.0 RFS (Odexed)
What do i do after i convert from froyo .dk28 to Froyo EC05 Prerooted/ClockWorkMod v2.5.1.0 (RFS Filesystem) Odexed. NO DATA WIPE/LOSS. When i go to reboot, to apply sdcard: update zip, it stay on the screen.
i'm stuck on the clockworkMod Recovery v2.5.1.0 boot screen. What to do next to go to EI22 gb
very little information to go by:
Q: are you able to reboot to system from you recovery?.....if the only thing that happens from recovery is a bootloop, sounds to me like you're in a soft-brick.........no worries, this can be fixed with Odin.
......try Odin (back to stock froyo EC05) w/ your pc......one of the sticky's on this forum is the 'how to wipe back to stock EC05 w/ Odin'.........also, a few posts above here is a post by androidcentral advisor Paul627g.......read that post first.
Good luck.
kuzmaj05
