Odin Effects on Different Captivate Build Numbers
I have a 1110 build. Anyone have one too? I want to root it but so far it refuses to open file, like Z4root.apk, then goes back to 'home' screen. Any ideas?
mine is 1105 and it bricked had to buy a tool
This is something that I don't think there is enough clear information on, so I figured it would be a good idea to figure out what goes with each number, and put together a guide.
If you have ever used Odin, please post the following information:
Build Number (4-digit number located under your battery, should be 10xx)
Did your 3-button combo for download work before using Odin one-click (not the manual Odin)?
Did it work after?
I'll update this as more people post. Here's what I have heard so far:
1007 & under: 3-button combo always works, should never break.
1008: 3-button combo does not work, jig (or fix) required for download mode.
1009: unknown
1010: 3-button combo works before Odin one click, not after. (see below)
1011: unknown
1012: mixed results, may be like 1007 or 1010
*If you have a 1010, see this post for how to use Odin and not brick. Don't freak out when Odin soft-bricks your phone and 3-button doesn't work, a jig will still work.
Build 1012 and 3-button results in download on i897 display so, I am good with regard to this test. Need to read more and root it as nothing has worked yet (i.e., SuperOneClick v2.2 & Kingo Root)...despite being late to this game!
At this date I have to ask what version of ODIN I should download. I only see three versions prominently displayed on the ODIN homepage.
No members online now.
cany
