I'm still new to all this, so I figured its better to ask questions first. I flashed Superclean 2.8 but I wanted to make a backup of my phone, but from what I've read you make backups with ROM Manager and with Superclean we aren't suppose to install ROM Manager right?
My personal suggestion it to root your phone and use
Titanium Backup. There are some other applications that do similar functions, but I cannot attest to them. I purchased Ti Backup, and it's fantastic.
When you run it the first time, it will ask you for root rights. Approve the rights if you've rooted, otherwise it won't work.
There will be a Batch function for you to run in Titanium (there is a free and paid version) where you can backup all of your applications and system data. I would personally just backup the applications.
Then pull the trigger. Follow the instructions DXC has laid out on the first post, and when you get the phone booted back to the desktop, it will already be rooted. Download Titanium from the market and then use the Restore applications function, and then sit back and watch your apps get restored.
The only problem with the unpaid version is that you have to tap and approve all of your apps. With the paid version, you tap once to start the process and then come back when done... and everything is automatically approved.
I read all 200+ pages before I opted to pull the trigger, so don't feel bad if you're feeling cagey about pulling the trigger. I also read all of the posts from Adrynalyne's thread that was just recently closed and started over. So you're looking at some 400 pages, just between two threads.
DXC really does have it laid out pretty straight forward. The short version of what to do:
- download update.zip and place it on the the SD card (not in a folder)
- download and install the drivers
- download your choice of ROM packages (personally EB16SC28_DXC.tar is my choice if you want all of the Verizon stuff removed and the cleanest phone)
then follow steps 4 - 16 on that first post to get your phone flashed.
If you have issues with flashing, there are several people around here to help get you through the issue.
