[Odin] Froyo leaked packaged custom ROMs w/root and clockwork **UPDATED**3/25
I wonder if it's just voodoo and EB01 that causes the issue. Because I'm using SC 2.6 w/voodoo dummy kernel and 720p works fine.
I flashed eb16sc_dxc to my phone. If the phone is plugged in i have no problems. If i unplug it and leave it sit for a few minutes it will not come back on and I have to pull the battery. It works as long as i dont let it sit. Any ideas?
Paul
Thanks DroidXcon for the fast reply
Tried to falsh again and it was better lasted 15 - 20 min before i had to pull battery. Also battery is draining fast. One thing i noticed is that after i flashed the phone it showed 1.47gb of free space. Should it have been more after a fresh load? Should I flash 2.5?
Sounds to me like your battery is failing can you borrow someones to test this
Sent from my SCH-I500 using Tapatalk
@Dave, you had alot of trouble when you first started flashing its possible something in your memory got written wrong , i would use this
http://forum.androidcentral.com/ver...nmodified-stock-engineering-test-package.html
to scrub your phone clean, then come back and try again with superclean now that you have a better idea of the steps to take you should come out clean
Do I go thru ODIN again with this? Once it is scrubbed, will it be ok to go straight to SC2.6x or should I go with SC2.4?
Yeah odin..but it will wipe data so it doesn't matter what version of 2.6 you use
Reactions: Dave95b
DroidXcon,
Sounds like he's got the sleep of death. It doesn't sound like the battery is dying so much as it can't wake up after going to sleep or low power mode.
I posted some information about the SoD patch from Adrynalyne SoD post .
Paul
My post was to help Paul by providing step by step by applying the patch.
